3 unity of ni 9219 on one chassis
I need to measure strain of 3 jauges (every jauge acquire strain of 3 directions).
I would to know if i could use 3 unity of NI 9219 on one chassis?
Because i tried to use 2 acquisition board and i get an error! I should use only one board!
Message 1 of 11
(4,303 Views)
I don't understand your question. The 9219 has 4 channels. What do you mean by 3 unity?
Message 2 of 11
(4,295 Views)
Hello
The picture of the unity (or module) is attached. In fact, i would to use 3 of it on the same chassis ( in the second picture).
Thank you very much,
Message 3 of 11
(4,266 Views)
What you mean to say is that you want to use 3 channels of a single 9219, if I understand your Google translation correctly. As already mentioned, your device has 4 channels so you can certainly use less than or equal to that number. For connecting them, please provide some details on the actual sensor/gauge.
Message 4 of 11
(4,253 Views)
It is not channels! I mean 4 pieces of NI 9219 which i will use on the chassis!!
I have 9 strain gages to connect !
Message 5 of 11
(4,244 Views)
Accepted by M.A.H
Simulating a cDAQ-9174 Chassis with 3 cDAQ-9219 modules in NI MAX does not generate any errors hence I'd say yes, it is possible.
To make sure, I strongly recommend to contact your local NI service.
Regards, Jens
Kudos are welcome...
Message 6 of 11
(4,233 Views)
Unfortunatly the 9219 is one of the devices that does not support a single Task with phyical channels on different devices.  You will need 3 Tasks (one for each device)
An Action Engine somewhat simillar to this example (where I ran into a simillar situation with multiple cDAQ devices) can help out a lot:
Message 7 of 11
(4,226 Views)
Thanks very much  jg69.
I would know also how would i calibrate the NI 9219.
Message 8 of 11
(4,224 Views)
Accepted by M.A.H
@M.A.H wrote:
Thanks very much  @JensG69.
Assuming you want to account for the strain guage variabilities:  Rotate the guages and place a known mass on top.  Record the measurement with and without the mass.  Adjust the channel's "Scale" Slope and offset per actual recorded values.
Calibration of the 9219 is a different matter- It should have shipped with a certificate of calibration.  Well, actually, they are on-line and you look them up by serial number from "MyProducts" on your ni.com profile (you do need to register your products!)
Message 9 of 11
(4,220 Views)
I have registred my product now. The system must verify the product then i will download the certificate!
I would thank you another time for your answers.
Message 10 of 11
(4,203 Views)
