30 days activation programming
Hi jeyanthi,
if the user runs your program and the test period isn´t expiered then write the current data into the registry. With every start of your program check if the stored date in the registry is older then the current date on the running machine. If not someone has changed the date.
Mike
Message Edited by MikeS81 on 08-20-2008 09:03 AM
Message 11 of 13
(796 Views)
is there any secure way in programming to knw the user changed the dates?
in previous post u have reply about the server solutions .How to do that?
Message 12 of 13
(759 Views)
Hi jeyanthi,
what do you mean with your first question? i thought i already described how i think it can work. Smiley Happy You can use the server solution like ni. Before using the program you have to register your copy and you get your key. You can also check every day if the current copy is still valid.
Mike
Message 13 of 13
(741 Views)
