34970A error on instrument but not in code?
Can you run the Version function (Utility palette) and see what you get for the 3 module information indicators? You can also manually open/close a module relay with the Switch function (Action-Status palette). Set the channel list to 101 and see if the instrument reports an error.
Message 11 of 12
(550 Views)
Does it work using the EZ Temperature vi? Have you downloaded the 34970A vi's from NI?
I would work with these (EZ vi's) until you get it working then you can work out your own command strings.
=== Engineer Ambiguously ===
Message 12 of 12
(545 Views)
