feature request for labview - selective clean up in block diagram
I was introduced to LabVIEW 8.6 this year and it has an awesome facility for clean up diagram. But i find that it needs to be tunned up a little finer.
I would like to give one suggestion
Add an option of selective clean up diagram pressing which only the selected terminals should be arranged automatically. This really helps cause otherwise the clean up diagram sometimes does bad then doing good, especially when you have a big block diagram and there are certain chunks of terminal which you want to keep together. Moreover all the comments also gets arranged, sometimes making no sense if not placed intelligently 😉 (eg, placing them in respective 'structures')
clt+u is great, adding the above feature will make life wonderful!
Thanks!
(2,942 Views)
The fine people at NI are way ahead of you on this one.
Tim Elsey
Certified LabVIEW Architect
(2,940 Views)
Thanks!
Great idea!
Ben
(2,937 Views)
@Tim
i just realised that,
sorry 🙂
Message Edited by Ujjval Shah on 04-30-2009 12:05 PM
(2,935 Views)
