How do i synchronize variuos daq sytems?
Hello
i am new user of labview. I am trying to aquire signals from a NI9211 and from an NI 6008 but the NI 6008 has a delayed response.Anyone have an ideia of what is happening?
Regards
Teixeira
(2,701 Views)
Usually you would set the trigger typr on the daq taksk and then issue a trigger from another source (digital output) the tests will start at the same time, this is hardware triggering. I would check if the devices you have support a start trigger.  also you can set up your channels to share an external clock to improve synch.  With USB devices determinism is not great so a hardware triggered start should give you better results.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,686 Views)
