3D Cartesian Coordinate Rotation
3D Cartesian Coordinate Rotation (Direction) VI, has a input  "rotation matrix type", I can not understand the Direction Angles. when I use the defaut, it is wrong.
xin
Certified LabVIEW Architect (CLA)
Certified TestStand Architect (CTA)
(2,956 Views)
  • If you say something is wrong, tell us why and what result you expect instead.
  • rotating a [0,0,0] point with give you a [0,0,0] result, no matter how you rotate.
(2,912 Views)
The Inputs of the "3D Cartesian Coordinate Rotation (Direction)" VI are explained in the documentation, e.g. here: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/coordinate-llb/3d-cartesia...
The three arrays to the top left are your points. Enter some coordinates other than [0, 0, 0] to see the effect of the rotation.
Also, please use a smaller font.
(2,902 Views)
Your matrix is not a matrix of directional cosines because the determinant of it is not unity.
(You only have three degrees of freedom, so you cannot chose 9 random values. they are interdependent. How did you generate the matrix?)
(2,870 Views)
