3D Drawing to Window Refnum
I'm trying to construct a SubVI that takes Scene and Window refnums and draws new 3D objects (spheres) with xyz coordinates defined by an array input. Every time I use this VI my initial 3D image inside the render window dissapears when the SubVI executes, my intention being to draw new objects to it. See the screenshot attached.
Any help is much appreciated, thanks.
(3,798 Views)
Accepted by FiberOptix
Nevermind, I just figured it out. I was quite close there.
(3,787 Views)
Hi FiberOptix,
Is it possible you could explain how you solved the problem? It would be beneficial for other people with similar problems in the future, thanks!
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(3,703 Views)
@JohnMc19 wrote:
Hi FiberOptix,
Guessing now...
Use the output of the SR?
Ben
(3,697 Views)
