3D-Graphs don't work on current target cRIO-9063
i'm new to Labview and trying to find a solution for this.
I have the problem that my 3d-graphs don't work when i use them on my current target.
Setup: Professinonal Development system; NI cRIO-9063; labview 32 bit.
When i use the 3d-graphs in a blank vi then everything works fine. but if i open the same vi on my current target (cRIO- 9063) then the graph is broken. Or if a open a new vi in my current target then the option to insert a 3d-graph isnt even there.
When i add a vi with a 3d-graph to my project with the target cRIO-9063, then in dependices i see several 3d files. In the Error list some of these files show up with errors like "Wire:Type not supported in current Target".
My Question is: Does cRIO- 9063 not support 3d-graphs (couldn't find anything to that on the internet) or didnt i take a necessary step so that the graphs work on that target.
Thank you for your help!
(2,296 Views)
Accepted by Trustin
3D graphs are not supported on RT target (along with subpanels, Xcontrols, and 3D picture controls).
Se https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/design-considerations-for-display...
Marc Dubois
(2,279 Views)
