3D Picture Control Crashes LabVIEW
Hello again
I appreciate you may not have had time to act on my previous post, but I have looked into your laptop specifications and you do have the latest driver. Could you please confirm that this is your laptop and you have the standard Intel graphics card as shown on the spec sheet.
Do you have other laptops of the same spec within your department/office? Does the 3D controller work on these machines?
Another thing you may like to try is repairing LabVIEW using the repair mode on the install disk?
Please let me know how this goes.
Stephanie L
National Instruments UK and Ireland
Message 11 of 26
(1,958 Views)
Yes - I can confirm that the graphics card is the standard Intel HD Graphics driver (which I believe is part of the processor).
I have tried shutting down all unnecessary programs and features (e.g. anti-virus etc.) and the problem still occurs. I have also tried opening the example VI from windows (instead of having LabVIEW open first) and there is no difference.
I will however try repairing it now.
(blog)
Message 12 of 26
(1,950 Views)
Hi Sam
Do you have another E6510?
Stephanie L
Message 13 of 26
(1,940 Views)
I have just asked my colleague who has LabVIEW installed on exactly the same laptop (E6510) and the 3D Picture Control works fine for him. He is however using Labview 8.2, whereas I am using 2010.
Repairing LabVIEW did not fix the issue.
(blog)
Message 14 of 26
(1,935 Views)
Hi Sam
I have looked into the error signature and have found that it is a fairly common application error and it is normally linked to memory access, but I have also been talking to a colleague who had a similar problem with an XP operating system, when he updated to Service Pack 3 there were OpenGL compatibility issues.
I have found this which may help you find the root of the problem, but make sure you have the newest version of OpenGL and all of your drivers are updated.
Stephanie L
Message 15 of 26
(1,925 Views)
Unfortunately the only thing in that thread that was helpful was the OpenGL interceptor - however it would not attach to the LabVIEW executable to product error logs.
As for OpenGL - I have run a tool called DoctorGL which has produced the following output:
Video Card Vendor:    Intel
Renderer:             Intel(R) HD Graphics
OpenGL Version:       2.1.0 - Build 6.14.10.5258
GLU Version:          1.2.2.0 Microsoft Corporation
Current pixel format: 6
Pixel Formats supported by this video card
# Type Flags Buf Type Color(R-G-B-A) Z-Depth Stencil Accum(R-G-B-A)
1 ICD 00000024 SGL RGBA 32 (8-8-8-8) 0 0 0(0-0-0-0)
2 ICD 00000025 DBL RGBA 32 (8-8-8-8) 0 0 64(16-16-16-16)
3 ICD 00000024 SGL RGBA 32 (8-8-8-8) 16 0 0(0-0-0-0)
4 ICD 00000025 DBL RGBA 32 (8-8-8-8) 16 0 64(16-16-16-16)
5 ICD 00000024 SGL RGBA 32 (8-8-8-8) 24 8 0(0-0-0-0)
6 ICD 00000025 DBL RGBA 32 (8-8-8-8) 24 8 64(16-16-16-16)
7 ICD 00000425 DBL RGBA 32 (8-8-8-8) 0 0 64(16-16-16-16)
8 ICD 00000425 DBL RGBA 32 (8-8-8-8) 16 0 64(16-16-16-16)
9 ICD 00000425 DBL RGBA 32 (8-8-8-8) 24 8 64(16-16-16-16)
10 GEN 0000007C SGL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
11 GEN 0000007C SGL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
12 GEN 00000465 DBL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
13 GEN 00000465 DBL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
14 GEN 0000007C SGL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
15 GEN 0000007C SGL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
16 GEN 00000465 DBL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
17 GEN 00000465 DBL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
18 GEN 0000007C SGL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
19 GEN 0000007C SGL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
20 GEN 00000465 DBL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
21 GEN 00000465 DBL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
22 GEN 00000078 SGL RGBA 24 (8-8-8-0) 32 8 64(16-16-16-0)
23 GEN 00000078 SGL RGBA 24 (8-8-8-0) 16 8 64(16-16-16-0)
24 GEN 00000078 SGL RGBA 24 (8-8-8-8) 32 8 64(16-16-16-16)
25 GEN 00000078 SGL RGBA 24 (8-8-8-8) 16 8 64(16-16-16-16)
26 GEN 00000078 SGL CI 24 (8-8-8-0) 32 8 0(0-0-0-0)
27 GEN 00000078 SGL CI 24 (8-8-8-0) 16 8 0(0-0-0-0)
28 GEN 00000078 SGL RGBA 16 (5-5-5-0) 32 8 32(11-11-10-0)
29 GEN 00000078 SGL RGBA 16 (5-5-5-0) 16 8 32(11-11-10-0)
30 GEN 00000078 SGL RGBA 16 (5-5-5-8) 32 8 32(8-8-8-8)
31 GEN 00000078 SGL RGBA 16 (5-5-5-8) 16 8 32(8-8-8-8)
32 GEN 00000078 SGL CI 16 (5-5-5-0) 32 8 0(0-0-0-0)
33 GEN 00000078 SGL CI 16 (5-5-5-0) 16 8 0(0-0-0-0)
34 GEN 00000078 SGL RGBA 8 (3-3-2-0) 32 8 32(11-11-10-0)
35 GEN 00000078 SGL RGBA 8 (3-3-2-0) 16 8 32(11-11-10-0)
36 GEN 00000078 SGL RGBA 8 (3-3-2-8) 32 8 32(8-8-8-8)
37 GEN 00000078 SGL RGBA 8 (3-3-2-8) 16 8 32(8-8-8-8)
38 GEN 00000078 SGL CI 8 (3-3-2-0) 32 8 0(0-0-0-0)
39 GEN 00000078 SGL CI 8 (3-3-2-0) 16 8 0(0-0-0-0)
40 GEN 00000078 SGL RGBA 4 (1-1-1-0) 32 8 16(5-6-5-0)
41 GEN 00000078 SGL RGBA 4 (1-1-1-0) 16 8 16(5-6-5-0)
42 GEN 00000078 SGL RGBA 4 (1-1-1-8) 32 8 16(4-4-4-4)
43 GEN 00000078 SGL RGBA 4 (1-1-1-8) 16 8 16(4-4-4-4)
44 GEN 00000078 SGL CI 4 (1-1-1-0) 32 8 0(0-0-0-0)
45 GEN 00000078 SGL CI 4 (1-1-1-0) 16 8 0(0-0-0-0)
(blog)
Message 16 of 26
(1,918 Views)
Hi Sam
As you know I have tried running the 3D VI's on LabVIEW 2010 and have come across no issues, and there doesn't seem to be issues on your colleagues E6510.
If you have the latest versions of directx, OpenGL and the drivers and have also repaired LabVIEW then the problem unfortunately, probably lies with your PC.
I recommend looking at the details of your colleagues PC to see if there are any differences other than the LabVIEW version as you know the 3D control works for them.
I hope this has been of some help
Stephanie L
Message 17 of 26
(1,911 Views)
I have just installed a trial version of LabVIEW 8.2 - which is the same version that my colleague is using and I can use the 3D Picture control without any problems.
Surely this must mean that the problem lies with the version of LabVIEW I am using?
(blog)
Message 18 of 26
(1,909 Views)
Hi Sam
Have you tried opening LV2010 and running it on there since it worked on 8.2? Again making sure there are no other programs open, as they may interfere with the memory.
Cheers
Stephanie L
Message 19 of 26
(1,901 Views)
Yes I have tried that - didn't work 😞
(blog)
Message 20 of 26
(1,891 Views)
