3D array manipulation
Hi
Please bear with me for the long question as I wanted the question to be very clear.
I have a 3d array with many pages as follows
I also have the maximum number of rows in each page that should be considered as below.
The output is expected as
  1. 4th column of first row in each page must be zero
  2. If the next row first 3 columns is same as earlier row first 3 columns then the fourth column of that row must be same as fourth column of earlier row.
  3. If they are not same increment the fourth column of the earlier row and continue till maximum rows have reached.
Sample Outputs
Any help to solve this is highly appreciated.
(4,347 Views)
Post what you have.
(4,333 Views)
Hi..this is something like an assignment that I have. The inputs are the first and second images and the expected output is the last image.
(4,327 Views)
Make an effort, post it, and we'll help you out.
Or post a concrete question about a detail where you got stuck.
We're not going to do your assignment.
(4,318 Views)
I don't expect anyone to do my work. If I can come up with an algorithm, do understand that I have tried.
(4,314 Views)
Good.
You have the algorithm, as described in your OP.
Where did you get stuck?
(4,307 Views)
Accepted by eddy1990
Hi
I tried to figure out a solution. Not sure it is the effective way to achieve my objective. But still it works.
(4,275 Views)
