3D-graph
Hi Alex,
an you possibly save it as a labview 2009 file?
best regards
KF
Message 11 of 15
(1,398 Views)
sure,
btw: the vi attached is mainly based on the"National Instruments\LabVIEW\examples\analysis\plat-intp2Dxmpl.llb" example.
Message 12 of 15
(1,386 Views)
You can see the problem with Alex his example again, I will have to make up data for points in the x-y mesh which are actually not part of my surface, oherwise I will get a skewed picture. For adding colours, Ben's car example gives a start I think:
http://forums.ni.com/t5/LabVIEW/3D-graph-to-plot-surface-data/m-p/880161#M398111
best regards
KF
Message 13 of 15
(1,374 Views)
thx for the link, in the meantime I re-used Sam Rogers idea, as it's based on a 3d scatter plot:
http://forums.ni.com/t5/LabVIEW/How-to-display-4d-data-within-a-3d-scatter-plot/m-p/1402738
please explain "irregular shape" --- where's the problem with rectangles?
it should be always possible to fit an irregular shape in a rectangular bounding-box;
moreover,
when you change  the interpolation method for example to "linear" instead of "nearest" and look at Zi
the cell's which are not part of the surface contain NaN
Alex
Message 14 of 15
(1,361 Views)
I rearranged the data in 2D-arrays to get the correct surface. I added NaN to non existing Z-points. How can i scale the plot? I know I can hit XY, YZ, XZ plane and scale it myself, but if I make the scale smaller, ie 200, you can still see the surface higher than the scales. Is there any control I can add, to atomatically scale it in a proper way.
I am trying to get the 4D plot now like Ben
Best regards
KF
Message 15 of 15
(1,339 Views)
