3D picture control using sensor mapping vi
Dear Sir/Madam,
Hi i am using labview 8.6, in this version 8.6 i am not sure whether i found a bug or not i went to programme>graphic and sound>3d picture control. When i place the 3d control if show like frame and i move around the frame like duplicating. I am using VRML in labview 8.5 to control 3D model, in version 8.5 it can display very well but in version 8.6 it doesn't appear at all. Hope to help me how to display 3d picture control using VRML in labview 8.6. One more thing is that i place sensor mapping vi into block diagram when i load model the 3d model cannot appear, i acting same as labview 8.5.
(4,309 Views)
Hi Zaw WIN Maung,
     I have attached the VRML examples VI for you.IT can load in 3D picture control.I think should be ok.
You can try to explore the code.
regards.
S.Ahmad
AE.
(4,262 Views)
  • Hi Sir, i cannot open the file. Once i open the file it says close the program or check for online solution. can u give other example?
(4,237 Views)
 I only have this example but you can try to download it from the website.I give you the forum link.Youc an download it from there and try again.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=354353&view=by_date_ascending&page=2
Regards.
S.Ahmad
(4,234 Views)
