time
I uses timestamp so that if i save my values, there's time to show. Currently using 'Get time/date in seconds' but the graph display a time that is not present year/present time. Is it i uses wrongly? Because if i insert 'format date/time string', the output is in string. Did i do wrongly?
Thanks & Regards,
Isa
Message 1 of 9
(4,768 Views)
Hi Isa,
can you please show the place where you connect your data to the graph?
Mike
Message 2 of 9
(4,741 Views)
I put it in the idle case.
Thanks for the help (:
Isa
Message 3 of 9
(4,699 Views)
Hi Isa,
i meant the graph indicator. Can you show this place please?
Mike
Message 4 of 9
(4,676 Views)
Hi Mike,
Sry for the trouble and thank you.
Isa
Message 5 of 9
(4,649 Views)
I would say that the problem is that the routine acquiring the data is not returning a time value that is related to clock time. In the first image you posted, there is a timestanp shown on the x-axis of the plot. The year is only shown in two digits: "04". If you extended the format to include a 4-digit year, does it say 2004 or 1904?
Also I'd like to see what is inside that subVI labeled "LCOD/UI RD Control"
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 9
(4,626 Views)
Below attached the things that you need. Actually, i did insert an indicator at the current time. It shows current timing. Where gone wrong?
Thanks & Regards,
Isa
Message 7 of 9
(4,609 Views)
Actually I was needing to see the block diagram of the subVI I mentioned.
Mike...
LabVIEW Champion
Message 8 of 9
(4,589 Views)
Isabella,
It would much simpler if you just posted the actual VI and subVIs. Trying to debug an image is just not practical and when you post partial images, it's impossible.
Message Edited by Dennis Knutson on 01-22-2009 08:42 PM
Message 9 of 9
(4,574 Views)
