3D surface plot
the data points are on z=0,1 and 2
that I wanna make a 3D surface graph and use the numeric controller to change the cross section between the z plane and the surface graph....so that if I putted z=1.5   the output will be the points of the cross section.
Message 11 of 19
(3,941 Views)
Oh.  are the three data sets supposed to be different levels of the same 3d wing shaped object?
Tim Elsey
Certified LabVIEW Architect
Message 12 of 19
(3,936 Views)
yes that was correct....and those points are found from the blade...
Message 13 of 19
(3,934 Views)
Sounds like you want to create a mesh surface that conforms to your datapoints, but you can interpolate different z values from??
Message 14 of 19
(3,906 Views)
yes...I wanna use the given data point to create meshing surface...and give the desire -plane...the program pull out the nodes from the crosssection
Message 15 of 19
(3,901 Views)
Here is something I used to create a mesh using mathscript and the mathscript viewer.
Message 16 of 19
(3,892 Views)
sorry that I you do version 8.5?? that I can't open the file...thanks
Message 17 of 19
(3,881 Views)
Here you go
Justin Parker
Product Support Engineer
Message 18 of 19
(3,849 Views)
Starting atpost #7 of this thread I start a tutorial exaplaining how to use the 3d Graph to plot multiple curves and surfaces.
If you want your final image to look like an air foil your are going to have to present your data such that adjoining points in your surface are adjacent in the data set. THis thread shows a quick hack of a a car rendered in 3d.
If you want it all to be one color you will have to set teh color mapping to none.
Idividual ribs of the wing can be added as sepearte plots to over-lay the surface.
Have fun!
Ben
Message 19 of 19
(3,836 Views)
