3D surfase in Linux
Hello.
I use LV 8.6 on Linux PC. I have  3  1D array (3 vector) x,y,z. I want to plot  3D surface but  for building 3D surface it need build Z 2D matrix. How does it  possible to plot 3D surface with 3 1D array on Linux PC????
(3,842 Views)
Array 1 - X values?
Array 2 - Y values?
Etc.
André (CLA, CLED)
(3,833 Views)
Yes.
Array 1 - X values.
Array 2 - Y values.
Array 3 -Z values. How to build 3D surface in Linux???
(3,825 Views)
Ok, you've asked this question before, so this is actually a duplibate post.
But the other thread seems to be a dead end. Please don't post the question
again...
If you have 3 1D arrays (x, y and z), and you want a 2D surface, you're the
only one who knows how to do this. You can convert a 1D array to 2D with the
"reshape array" function, but knowbody but you knows if this is what you
want. You need to specify.
Wiebe.
(3,797 Views)
Unfortunetly it not corect solution (it's fake). So in this case you get matrix with real data and 0 (zeros) but  it is fake data.
(3,795 Views)
