Showing results forĀ
Search instead forĀ
Did you mean:Ā
3POLE TOGGLE SWITCH
HOW CAN I CREATE A THREE-STATE TOGGLE SWITCH?
(3,788 Views)
Try this one [link removed; example no longer available] from NI
(3,785 Views)
It depends on how you are defining "three-state" (which is quite different from 3-pole). Boolean variables will always have one of two states, True or False. A control cna be diasabled so that it cannot be changed by the user, but it will still have one of the two states.
If you need a three-state variable you could use a numeric control like a slider and customize the appearnce to have a True State, a False State, and a None State, where True = +1, False = -1, and None = 0.
Lynn
(3,783 Views)
GRACIAS!!!!
FRED-FRED
(3,774 Views)
I am having the Labview 10, i cant open theLabview 5.1 VI.
cant them convert to LabView 10 ?
thanks
sam
(3,439 Views)
Post the VI you want converted to the Version Conversion Board.
Lynn
(3,434 Views)
