3d PLOT DIRECTION
How can i programically change the 3D graph direction that I want to view.
I know how to view and adjust the projection, but what about the graph's direction meaning XY, XZ, YZ, and user defined...
Thanks!
(4,017 Views)
There is a projection properties function buried under the graphics&sound, 3d graph properties. Wire a true for the projection.
(4,014 Views)
I am not talking about projections I'm reffering to the 3D plot direction VIEW.....
FredFred
(4,010 Views)
You can use a standard property node and wire it to the 3Dgraph out terminal. This will give you View latitude, View longitude View distance properties. I wired these into a bundle node and made an indicator inside a for loop. You can play with the properties and view before running to see how these values change.
(4,005 Views)
Use the view mode property in write mode and create a control. This creates a ring control with the XY,YZ,XZ and User Defined options.
(4,001 Views)
Thankx
(3,996 Views)
