while loop iteration stays at 0
i have labview 7 student editon. i am trying to do a while loop that increments and plots a sin wave. basically i am doing chapter 1 in Advaced labview labs. but when i run it i get a line. when i run step by step it looks like the iteration is staying at 0. any ideas. thanx.
(4,127 Views)
Hello, can you post the VI please ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,125 Views)
(4,118 Views)
Well... obviously you are new to LabVIEW, don't worry we all started from the bottom just like you 😉
In the right-bottom corner of the loop you linked a TRUE constant to the "stop condition", and this stop condition is set "stop if true".
So the loop executes just once and this is normal behaviour.
Have a look at the VI attached to see how to do it differently 😉 !
Epictetus
Antoine Chalons
(4,116 Views)
ah ha.
thank you for the help.
(4,112 Views)
Can you post the code somewhere?
(4,095 Views)
