3d bar graph in 8.6
Does anyone know is it possible to plot a 3d bar graph in LabView 8.6?
I need the bar graph rather than the surface plot as I don't want any interpolation between points.
At the moment the closest I can get is using the surface graph plotting points as large solid cubes, but this is almost impossible to read and very ugly.
If I could get it to fill in below the cubes it would be perfect.
It seems like there should be a bar graph available, its a fairly standard format.
Thanks for any help,
Darragh
(2,462 Views)
(2,453 Views)
