3d figure bounding box
I load some 3d model into 3d figure in labview. I need to find bounding box of that boject programmatically and then I am going to use clip plane on that object strating from minimum (object visible) to maximum (object invisible). Do You have any Ideas?
(3,121 Views)
I think I ve solution
I get vertex array from scene mesh and then I am looking for max and min x y z value and they create my bounding box.
I have no idea if this is elegant way to do that because i ve never used 3d picture and there is very hard to find good examples...
(3,101 Views)
Can you post the VI and the 3D model?
I.R.
(3,082 Views)
Vi and model  attached.
Next thing that i want to achieve after cutting plane is applied:
-Places where object was cut have to change color like this:
Any sugestions on this?
(3,071 Views)
Hi there,
At the following location you will find and example that is loading a 3D model and modifies the colour depending on some values that you pass (reading from a sensor).
You can convert the express VI to a subVI and see low level the implementation.
https://decibel.ni.com/content/docs/DOC-2059
I.R.
(3,059 Views)
