LVUTF -> RequirementID not showing in ATML report
I'm using requriements gateway and I wanted to use the ATML report out of the UnitTest framework in my project.
The issue I'm facing is when I run the UnitTest framework on my project the ATML est report does not contain the RequirementID elements.
I belieave I've configured it all right and I can't understand why it is not working.
Requirements gateway ships with an example of using the UTF ATML report. When I run the test in the example project the RequirementID tags are shown.
I'm attaching a snapshot of one of my 8 unit tests in my module: to show that I did set the RequirementID field in the UTF configuration.
However ... I get no luck and the report doesn't have the RequirementID.
Any help would be appreciated.
Maciej
(2,349 Views)
Accepted by topic author Mac671
Ok,
Problem between the keyboard and the chair.
If you go to project preferences, unit test framework, there is an option to select additional details in the Passed, Failed, and Error tests.
It is unchecked by default.
When I've selected the option the ATML now cointains the RequirementID tags I wanted.
(2,336 Views)
