3d picture
dear sir,
           I want to convert a jpeg file into vrml file,so pls give me suitable suggestion.
Thanks and regards
Jayanthi.k.
Message 1 of 10
(4,914 Views)
Hai,
Picture operations included with labview support loading of wml files(or vrml).  You can load a wml file in labview.
But i think there is no such function that converts jpeg to vrml.   If you want online conversion try using third party activex control that can do the job.
if image conversion is your criteria and not online conversion then there are numerous freeware downloads that converts jpeg to vrml.  Run a search you will get many.
With regards
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
Message 2 of 10
(4,898 Views)
dear sir,
     we devoleped roll & depth  movement of underwater vehicle in X-Y graph with 2dimensional rotational matrix using labview 7.1. we have to devolep this program for the 3 dimensional movement of the vehicle in labview 8.2. please send some useful examples and links. can we use 3D rotatinal matrix for this program, if it so,please give suggession for this otherwise give details about devoleping  program.
Thanks and Regards
Jayanthi K
Message 3 of 10
(4,872 Views)
Hi Jayanthi,
The simplest option would be to use a 3D graph, which will display 3D data on a 3D plot in an ActiveX object on the front panel.
Types of Graphs and Charts
https://www.ni.com/docs/en-US/bundle/labview/page/types-of-graphs-and-charts.html
Elizabeth S.
Message 4 of 10
(4,853 Views)
dear sir,
            Thanks for your reply.But How do i download a 3d picture(ie my vehicle in a 3d graph).Is there any possiblities.
pls suggest me with sample code and examples.
Thanks and Regards
Jayanthi.k
Message 5 of 10
(4,836 Views)
 Hi Jayanthi,
1) What format is your 3D picture?
2) Please look at the following link.  You will find that there are three different options for 3D graphs.
http://zone.ni.com/reference/en-XX/help/371361B-01/lvconcepts/types_of_graphs_and_charts/
Are you interested in a surface graph, surface and parametric graph, or curve graph?
3) There is an example of the 3D graph posted at the following website:
Plotting Multiple 3D Plots on a Single 3D Graph (Windows)
http://zone.ni.com/devzone/cda/epd/p/id/1028
4) The 3D picture control will add additional functionality:
-Exploring a 3D scene with the mouse
-Creating 3D objects from scratch
-Controlling an object
-Importing a 3D model from file
If you want to have this extra functionality, please look at the tutorial at the following link.  You will find example code towards the bottom of the page.
Create Advanced User Interfaces with OpenGL Based 3D Visualization
http://zone.ni.com/devzone/cda/tut/p/id/3170#toc0
There is an example posted at the following website:
Flexible Joint Control Design Case Study
http://zone.ni.com/devzone/cda/epd/p/id/3226
If you have further questions, please let me know whether you are interested in using the 3D graph or 3D picture control.
Elizabeth S.
Message 6 of 10
(4,818 Views)
dear sir,
         My picture format is jpeg file,I have attached my picture also.Which is the suitable for my application(3d graph or 3d picture).
Because I have no idea about 3d graph/picute,now only i am learning 3d graph/picture. pls suggest me .
Thanks and regards
Jayanthi.k
Niot
Message 7 of 10
(4,794 Views)
dear sir,
         sorry I forgot to attach the picture in a previous Thread.
Thanks and regards
Jayanthi.k
Niot
Message 8 of 10
(4,794 Views)
hai,
    sorry. I am disturbing you again and again.
I have no toolkit.so, i can not able to open above link .
Is there any Evalutaion for toolkit available.
I am using labview 8.2
Message Edited by jayanthi on 06-28-2007 01:06 AM
Message 9 of 10
(4,788 Views)
Hi Jayanthi,
You can install the 3D Picture Control Evaluation software at the following webpage:
http://zone.ni.com/devzone/cda/tut/p/id/4411
Please let me know if you have further questions.
Elizabeth S.
Message 10 of 10
(4,732 Views)
