3d rotating object
I was able to rotate 3d objects through this VI but I want to be able to center of the object instead of rotating around its edge
i have inserted the VI and the 3d object example
(2,477 Views)
Hi Joseph,
could you down version your VIs to version 2020?
FrankenChino
(2,425 Views)
Hello Franken
hopefully it works now
also, I have attached a picture incase if it doesn't
(2,410 Views)
Hi Joseph,
I think you should try to set the coordination of the Axis, try to apply the following VI to set the coordination.
FrankenChino
(2,401 Views)
Hey Franken,
thanks for explaining
here are the results, I'm not sure if combined both functions wrongly but it the same problem occurs it still rotate around its center
(2,381 Views)
Hi Joseph,
first you have to move the all the setups/initiolization VIs out of the loop, the loop is only used to repeatedly changing the x,y,z angle.
Did you try out changing the value of Input "Axis" of the "Set Rotation VI"?
I didn't purchase this Transformation Package, so I made some trick with snipping Tool, see pic below.
FrankenChino
(2,358 Views)
