Modbus with zelisodt gives error Error -1967353901 occurred at Shared Variable
Hi!
I'm trying to write data from LabiVIEW to the Zeliosft PLC from Schneider.  My program looks like this:
The IP adress for the PLC  is given as follows:
But when I run the program I get the following error message:
I'm using the DSC module.  And I'm using Ethernet Modbus.
Any suggestions?
Svein-Tore
(1,294 Views)
Hi Svein,
can you ping the PLC from your LabVIEW computer?
Have you tried to use one of those available Modbus libraries instead of DSC?
Have you tried to use plain UDP or TCP functions to handle the "Modbus over Ethernet" messages on your own?
(1,258 Views)
Hi GerdW!
Honestly I am a bit noob when it comes to this.  I have found a youtube video and have followed the instructions from it.  The problem here I guess is the ip adress for the PLC.  I'm not sure, but I have found it to be 85.16.110.236.  So to your questions:
 I'm not sure on how to do it.
I'm going to try.  I have started on a code that looks like this:
I think, if things is OK I will not get any error on the error out from the program.  I haven't tested this program though.
Have you tried to use plain UDP or TCP functions to handle the "Modbus over Ethernet" messages on your own?  I don't know how to do this.
BTW: I have to use Ethernet, so I think New TCP Master means ethernet?
Svein-Tore
(1,251 Views)
Accepted by topic author Svein-Tore
Finally I solved the problemn. I did some mistakes with setting the IP adresses.
(1,220 Views)
