3d scene 3d object
Hi all,
I have this problem: I'm creating a functional global variable that creates a 3d scene with x,y,z axes, then updates it adding 110 little 3d spheres. My problem is that when I create the scene with axes the result is a scene node refnum, and so I cannot add to this scene the spheres, because their property is scene object refnum. How could I manage it?
Here's the vi. The main is called Main Test.vi
Thank you!
Luke
Message 1 of 12
(5,953 Views)
Are you sure your code isn't casting to a SceneNode somewhere.  I thought it should be a SceneObject type.... Check the terminal on your global.....
Message 2 of 12
(5,944 Views)
Pay Attention to your SubVI's: SceneObject is coerced to SceneNode refnum when wired to 3D Picture
Message 3 of 12
(5,939 Views)
Like, for example?
Message 4 of 12
(5,938 Views)
Message 5 of 12
(5,933 Views)
Yes, sure, but I have to produce a 3d picture, not a scene object! How can I do?
Message 6 of 12
(5,929 Views)
They've answered your question. You already know how to produce a 3D picture from a sceneobject (you're following the 3D solar system example vi that ships with LV, right?)
Message 7 of 12
(5,912 Views)
No, I'm not following that example.
I don't know how to solve the coercitions...
Message 8 of 12
(5,905 Views)
Instead of having a 3D picture as a terminal on your sub-VI right-click the wire from the axis and select "Create Indocator".  then delete the 3D picture on your sub-VI and use the newly-created control instead.
Shane.
Message 9 of 12
(5,899 Views)
Ok, but it creates a scene object, not a 3d picture... ok, I could use only scene objects, but then I have to "convert" them into a 3d picture, and I don't know how to do this..! 🙂
Message 10 of 12
(5,896 Views)
