Pictures in labview
Is there anyway to open a picture in labview without getting a white background square shape around it?
(4,025 Views)
Hi recneps,
you should set transparency in your pictures. Using PNG may help too:
Using a PNG with proper transparency settings…
(Setting the picture indicator (or atleast its background) transparent may help too!)
(4,002 Views)
when i open the gauges that are in this link https://decibel.ni.com/content/docs/DOC-4819#comment-7956
on labview they dont have a white background on them at all, but if i take an image from google it adds in a white background. I did what you said but i dont want ot to have to have a new picture box where the image opens inside.
Can you check the link and download the file thats attached to see what i am talking about
(3,992 Views)
Accepted by topic author recneps
Hi recneps,
as already said before: you have to use pictures with alpha channel data embedded to have transparency!
Use some (good) image processing software (suggestion: GIMP) to set transparency in your pictures. Use PNG format as it supports transparency data…
(3,951 Views)
