3d surface plot
To create a graph with circular x and y axes like in the picture below and then divide this circular area into about 10 regions where i can input z values for each region to make them either rise or sink as desired. There aren't many examples available, so i'm seeking assistance.please help
(1,050 Views)
you will probably need to implement the algorithm yourself.
you probably have a 2D array of data, where each circle will be defined by x/y position of the data in the 2D array of data. Then use the 2D array element data to evaluate if it fits your pass/fail criteria
(1,005 Views)
