4 monitor executable slows down
Hello, I have a labview application that has executed just fine for a 2 monitor display. Now our client wants 4 monitors displaying different information(different vis). I have one of the screens on one of the monitors with a large listbox when I scroll thru it all my whole application freezes. I know the executable is still running because the application keeps recording data so I think is a display problem. Has anyone run into this problem? I would appreciate some help. Thank you
(2,511 Views)
Hi Bertha,
If it runs on 2 monitors I don't think it should give problem for 4 monitors. Can you tell us more about this behavior?
I have used 4 monitors before, with different sizes and resolution, never faced such problem.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,470 Views)
Hello Bertha,
I have some additional questions about your VI and system. You mentioned different Vi’s, are you running multiple Vi’s or a single Vi on 4 monitors? Also, what video cards and drivers being used at the moment?
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
(2,452 Views)
