How to capture an image with the camera axis
I have an camera axis. I can receive the video. Now I try to capture an image, for example when I push the button take. I do the .vi but I confused between the different Method.
SaveCurrentImage:Save the current Image
GetImage:Gets the data corresponding to the image currently being
displayed.
SetImage:Adds an Image to the Clipboard in the Bitmap format
That I search is to know if to capture image and saving when I push an button  I need to put all Icons so SetImage after Getimage and SavecurrentImage.
I put my .vi.
(6,415 Views)
Hi pseudo21,
if you run your vi, do you get the image you expect? If yes, then you can add an event structure to react on a button press.
Mike
(6,409 Views)
No, the .vi doesn't work and it that I don't understand
(6,401 Views)
Did you download the kit sdkfor using the axis media control active X:
http://www.axis.com/fr/techsup/cam_servers/dev/activex.htm
Did you test the sample and did you test with another language?
Nacer M. | Certified LabVIEW Architecte
(6,383 Views)
Yes I have downloaded the package and I have use in the .vi that did.
(6,374 Views)
You need path and file name with the jpg extension. I is working fine for me. But I exluded the SetImage node.
TIK
(5,670 Views)
