4 solar panel inputs(DAQ) produce 4 voltages. how can i get all 4 voltages out ?
the DAQ has been set up to read four voltages from a solar panel which has four pv cells in a north east south west arrangment. i need to get all four voltages out, as they will be different. once out they will be manipulated and the solar panel controlled (proportional feedback control)
(3,609 Views)
OK... have you looked at the DAQmx examples that ship with DAQmx? There are many examples that would apply to your situation. I would also suggest the Getting Started with NI-DAQmx: Main Page.
(3,607 Views)
thanks for the prompt reply ive tried looking the the examples, there are so meny and its hard for me to read the code as ive just started to use labview. but i will look again and if i have any trouble will ask again.
(3,592 Views)
