3D cause front panel to "freeze"
Im working on at data acquiring program, were Im at the moment use the signal generator to simulate future signals from a DAQ assistant. Now, I want 6 of the signals, to be shown in the two 3d graphs. But each time I run the program, the controls at the frontpanel are frozen (eighter can I scroll the window).
I cant figure out why ??
I tried to put the 3d graphs in its own while loop, to slow them down (and save cpu power), but it didnt helped. If I remove the 3d loop, the program runs fine.
I attach my VI, Ihope that its not to confusing 🙂
(3,050 Views)
By the way I run Lenovo T410 i7 64bit, with win7 and 64bit LabVIEW 2009 SP1
(3,046 Views)
Should I maybe use another 3D graph??
(3,024 Views)
Well I have tried another 3D graph and it seems to work much better, but ONLY in the 32bit version? I attach it, if someone wanna look at it, I think this is a solution to my problem.
(3,018 Views)
