Virtual printer
I have an old instrument that only outputs information (specifically a plot) to a printer. I would like to capture that output and log it on a computer using labview. Can labview do such a task? Can someone help me to get started? Gratefully, Adam
(3,251 Views)
I think you will need to provide more information. Virtually anything is possible with LabVIEW but we would need to know more details to be able to suggest solutions to your problem.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,249 Views)
In order for an instrument to output HPGL data, it must become the master on the GPIB bus.
LabVIEW will normally set your GPIB controller as the master, making it difficult to write LabVIEW code that to capture the HPGL. (only one master on the bus at a time).
There are some stand-alone utilities that can capture the HPGL output of an instrument; see this post:
http://forums.ni.com/ni/board/message?board.id=170&message.id=293491&query.id=1566415#M293491
Search the forums for HPGL...
(3,230 Views)
