488.2-NI and Dot.NET
What does National Instruments have that works with 488.2-NI and MS Dot.NET.
Have you tried it.
Gary
(3,629 Views)
Gary:
You should be able to use NI Measurement Studio with Visual C++.Net.
Haven't tried it though.
Douglas De Clue
ddeclue@bellsouth.net
"Gary Lindgren" wrote in message news:...
> Have you tried it.
> Gary
(3,629 Views)
Found this that uses a Measurement Studio control with
C#:
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/66692bb7ae4706ba86256bc9007ea3c2?OpenDocument
Trying to add an instrument driver dll to a new project as a reference, but VS chokes: can't build a wrapper. If you find anything, let me know. If I get it running, I'll post it
- WDK
Cincinnati
(3,627 Views)
Dear wdk,
    I am an artist working with LabView on a painting machine. I need a little one on one time with a LabView expert to get through problems I have. The forum would be great but problems are so simple I cannot even find solutions in the many manuals. My latest problems are taking an image, making an array and then performing simple math on the pixels. I am in the process of moving from RoboLAb to LabView. I spend so much time just studying and moving parts from other programs around, there has to be another way. tomlohre.com
Tom Lohre artist/scientist
Has a operating painting robot using RoboLab/RCX
Developing a LabView/ NXT robot that analyzes an image for aesthetic quality.
(3,335 Views)
Dear wdk,
(3,335 Views)
Hey Artisthos,
What you're doing seems really interesting.
There is an example titled Image To Array Example that will help you get going with converting the image to an array.
If you need help in doing some math to your array, I'd need to know what exactly you’re trying to do.
Most of the array manipulation VIs can be found in the Array Palette under programming.
Hopefully this helps!!
Aashish M
CEO
TransferFi
www.transferfi.com
(3,308 Views)
Thank you. I have tried to get the program you suggested to work many times. At the moment I am looking for a LabView Image expert out to the Universary of Cincinnati to help me. Soon I will format a exact document and start a new post. Thank you for your kind attention to my problem. Tom Lohre
(3,299 Views)
