i have compiled program with digital module(9401) but it does not give output
I have made a program using Digital Module(9401).
it compiles without any error but doesnot gives any output.
the same program works very well with analog module(9263)
please help me out.
i have also tried to compile examples given in example finder but their also is the same problem
direction of module is already set.
(2,556 Views)
I just wanted to clarify, are you using this module in a compactRIO chassis or a compactDAQ chassis? Thanks and I look forward to your response.
Cheers,
Jonah
Jonah Paul
Marketing Manager, NI Software
(2,543 Views)
Hello Sir
I am using Compact RIO(CRio-9014, Real Time Controller)
Digital module(NI 9401)
i have also tried several examples from example finder and examples available on internet,but that too compile properly without any error but doesn't give any output on oscilloscope.
waiting for your early reply
regards
avinash
University Of Catania
Catania,Itlay
(2,534 Views)
I believe the answer to what you are trying to do can be found here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=293355&query.id=4567
(2,527 Views)
