4d Plot using 4-(1d arrays) x-y-z and color
I'm trying to make a 4d plot using 4-(1d arrays). The 3D scatter plot shows my 3D data correctly. I collect data in a circular pattern now I want to plot that circular pattern using 3D contour or some other 3D plot but, I want to control the shell color mapping for each data point. I have attached my code. Still using LV2017
(4,981 Views)
you may have figured it out on your own,
but it appears to me you want to use
https://forums.ni.com/t5/Example-Code/3D-Plot-with-Pseudo-4th-Dimension-as-Intensity/ta-p/3996360
(4,883 Views)
I love it!!!  I picked cwColorSpectrum point style. How do I add the graphs color legend? So you can tell what the color equals what value.
(4,865 Views)
Accepted by topic author knows-just-enough
I' m not sure, I think such a thing doesnt exist for those active X 3d graphs ... maybe someone else knows?
roll your own:
attached is my quick draft, saved in LabView 2017
(4,851 Views)
Sorry for the delay I had to work on another project. Good idea on your work around. I tried it with other data sets and would sometimes error out if two values in color array were the same. I ended up using windows snapping tool and cutting legend out and placing array in min/max indicator next to legend.
(4,817 Views)
