4ga9toqa
We are running LabVIEW 8.6 and have the MAX Database Corruption Error. Tried using the Removal Tool but get a link to:
http://joule.ni.com/nidu/cds/view/p/id/1603/lang/en
We are using XP 32 bit operating system and cannot use the 2009 Run-Time Engine 64 bit version. Any solution?
(3,941 Views)
From your post I am not certain if you are headed in the right direction in fixing the root issue. I have found two articles that may better suite your needs. Take a look at these and post back with your results.
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
http://digital.ni.com/public.nsf/allkb/B9107A7F281F9B408625720B0078E5A8
____________________
Jimmy
Application Engineering
(3,894 Views)
