4ga9toqa
We are running LabVIEW 8.6 and have the MAX Database Corruption Error. Tried using the Removal Tool but get a link to:
http://joule.ni.com/nidu/cds/view/p/id/1603/lang/en
We are using XP 32 bit operating system and cannot use the 2009 Run-Time Engine 64 bit version. Any solution?
(4,212 Views)
From your post I am not certain if you are headed in the right direction in fixing the root issue. I have found two articles that may better suite your needs. Take a look at these and post back with your results.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MO7SAM&l=en-US
____________________
Jimmy
Application Engineering
(4,165 Views)
