5.1-5 is not equal to .1 ?
Hi all...
I'm using LabVIEW 8.5, When i tried to compare the result of difference of 5.1 and 5 (i.e 5.1-5) with .1 , the result was not equal. I used DBL representation.
Why is this so...?
(2,809 Views)
Your computer is binary, your number system is decimal. There will be rounding problems, using floating numbers for equality will get you into trouble. You should do an in range check of 0.1 +- 0.1 % or so. See wikipedia for more info.
Ton
My LabVIEW Ideas
(2,807 Views)
You could also multiply both input nuimbers by 10, convert them into integers, subtract them and test to see if the difference is equal to 1.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,766 Views)
