   Does anyone has a driver for the HP53310A (Time Domain Analyzer) that can obtain a screen shot?
Kaspar
Kaspar
Message 1 of 17
(4,641 Views)
Have you checked the instrument drivers available here?
Message 2 of 17
(4,638 Views)
  Yes, I have looked at the NI website, I did not get a "go get screen shot vi". So I will be getting the programmers manual to understand what the commands aare and make my own. When I do I will post it on this forum.
Kaspar
Kaspar
Message 3 of 17
(4,632 Views)
Hi Kaspar,
Getting a screen shot varies on the different instrument.  Some of which are easier to simply get the data and recreate the waveform either on a Labview Graph or within an Excel Spreadsheet etc.
However, if you want to get the actual screen shot, it may involve some "tricks".  The basic steps would be:
getting the spectrum
saving the spectrum as an image on the drive
with agilent, you may have to assign an image id (number) to the filename to allow a transfer
browse for the image name or id
transfer the image as a binary file to your PC.
As I said, this is a basic description.  It depends how easily your instrument will allow you to implement how it will actually be done.
I find that transferring the data is much easier.  And to save a screen capture, I save the Graph image from Labview.
R
Message 4 of 17
(4,618 Views)
   I am working in a enviornment where we are making the transition from a manual environment to a automated test environment. Being able to automatically capture a screen shot from test equipment will help to smooth the transition. Also capturing a screenshot will also contain other setting info about the instrument in addtion to the waverform shape.
Kaspar
Kaspar
Message 5 of 17
(4,587 Views)
Does your requirement allow you to save screenshots from a Labview Graph?  Or does it have to be the screen of the instrument?
R
Message 6 of 17
(4,585 Views)
   I need to be able to get a screenshot of the instrument.
Kaspar
Kaspar
Message 7 of 17
(4,581 Views)
Ok.  So let's focus on that.  I understand as we had a client back in 2001 who had the same requirement.  I had to do it using a R&S SA..  Before the days when instrument screen capture was an easier thing... 😉
From my original list, how far did you get?
"However, if you want to get the actual screen shot, it may involve some "tricks".  The basic steps would be:
transfer the image as a binary file to your PC."
Message 8 of 17
(4,578 Views)
   I have ordered the programmers manual for the instrument, it is not available on-line for HP, it is a discontinued instrument.  When the programmers manual arrives I will go to the local drugstore for a bottle of murine and see if I can find what command(s) are needed to obtain a screenshot. Stay tuned for further details.
Kaspar
Kaspar
Message 9 of 17
(4,572 Views)
You can actually find the manuals here:
http://www.home.agilent.com/agilent/techSupport.jspx?pid=1000001397%3Aepsg%3Apro&pageMode=MN&cc=US&l...
HP sold off their instrument stuff and spun off Agilent a long time ago.
The programming information is interspersed in the Operating Manual. I have not looked at it in detail, but it's possible it's similar to the procedure I had shown another poster with another instrument (a Rhode & Shwartz) here.
Message 10 of 17
(4,566 Views)
