6024 Acquisition through LabView
I have two PCI-6024E's running under LabView 6.1
I'm currently running a 200ms sample time / sweep time and want to speed that up, ideally by a factor of 10.
If anyone has any code modules that optimise the reading and writing through these cards I would appreciate some input on how I can do this.
Thanks in advance
(2,788 Views)
Hmmm, a 6024E can run at 200 kS/s, far greater than the 5 Hz acquisition rate you're currently at. For starters, in LV use Help->Find Examples and search for continuous or analog to find some buffered acquisition examples.
2006 Ultimate LabVIEW G-eek.
(2,788 Views)
