Anyone know what error -63043 is about?
I have a cRIO-9074 grabbing sensor data every ~2 seconds.
The Main PC program first uses Open cRIO VI Reference then enters a loop wherein a Read/Write Control reads data every 10 sec.
If a Read/Write Control error occurres, the Close FPGA VI Reference is called then the  Open FPGA VI Reference gets things going again.
I'm seeing three errors, -63043, -63195 and -63198, not all at once, not all the time, maybe twice a day.
Can anyone offer any insight?
mgroom
(6,581 Views)
Error 63043
Error 63195
My only suggestion for Error 63198 is to do a recompile/deploy and reboot.
I hope this helps you somehow!
Message Edited by macaba on 08-04-2009 06:02 AM
(6,564 Views)
Accepted by topic author Liquid_Crystal
Thanks Mark,
The app note you referenced, https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LeJSAU&l=en-US , points to the possibility of a delay in my WiFi communications link causing the -63043 error.
The -63195 error app note indicates a VISA  problem. Does a cRIO communicate as a VISA session?
Thanks again,
mgroom
(6,549 Views)
The 63195 app note does refer to VISA settings in its resolution so it is reasonable to assume it communicates as a VISA session.
(6,535 Views)
Hi Mark,
 I assume nothing when it comes to VISA, TCPIP, etc.
However, when NI speaks, its as though the heavens part and the voice of the Lord states the absolute!Smiley Wink
Thanks again, Merrill
mgroom
(6,528 Views)
