How to open browsing window, using a button?
I have multicolumn listbox with file folders in it. These are default paths in my program. I need to change the default paths by pressing the MODIFY button. For example, if I need to change the default path to Folder01, I need to select the first row of the listbox and then press MODIFY. Also after this I need to select files from these folders, I mean, if I press on "Selecting File From Folder01", must be opened the folder, specified by the first row of the listbox. Can you help me to do that? Thanks.
(2,949 Views)
I've done that quickly, maybe you should rework on it but that should be OK : to understand this solution you must learn about event structure and property nodes, so you should have a look at it if you want to understand what I've done.
Best,
(2,936 Views)
Thank you very much! That was very important to me :).
(2,922 Views)
