64-bit integers in activex
Hello:
I have some COM objects which I'm trying to use in LabVIEW.
I'm was able to use the "Automation Open", however when I use the "Invoke Node", I noticed that some functions are not usable and are grayed out.
I asked the developer of the COM and he said that it seems that the functions that are grayed out are using 64-bit integers.
I was wondering if anybody out there were able to successfully use 64-bit integers in activex for LabVIEW
(3,384 Views)
Just curious, what's yur LabVIEW version?
(3,368 Views)
Hello altenbach:
I'm using LabVIEW 8.5.1
(3,355 Views)
Hi DonPogi,
This is an issue that seems to be a continuing problem with ActiveX 64-bit integers. I would encourage you to submit a product feedback at www.ni.com/support to get your information to our R&D department so they are aware of the issue.
A possible workaround is to put the 64-bit data into a wrapper to convert the datatype to one of the supported types. More information about these datatypes and what is supported can be found at the following url:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vbcon98/html/vbconcreatinginterfacesforusewithimplementsstatement.asp
Thank you for the information, and let me know if there is anything else I can do for you on this.
Stephen S.
Applications Engineering
(3,335 Views)
