Setting Numeric Controls to a Constant?
This is a very simple task that is only meant to save me some time. In the front panel, I have a few Numeric Controls. Is there a way such that every time I open the VI, those Numberic Control are at values that I've set in my last VI run so that I don't have to initialize it every time I open it? (eg. the values don't change when I closed the VI and open the VI again) I would prefer not to change the Numeric Controls to indicators or constants.
(2,951 Views)
You can use Default Values:Make Current Default method.
Warning: this method not available in Run-Time Engine.
regards,
Andrey.
(2,946 Views)
Ah, that's what I was looking for. Thanks!
(2,944 Views)
