64 point FFT
Hello sir,
     I want to know how to compute 64-point FFT in LabLIEW. There are 64 inputs which are complex numbers. My whole computaton has series of blocks which are given below:-
1 stage- input block
2 stage- 8-point FFT
3 stage- Multiplier unit
4 stage- 8-point FFT
5 stage- output block.
The 8-point FFT computes FFT of first 8 samples then next 8 and so on...
(2,873 Views)
Accepted by nigdi
Most people computing an FFT in LabVIEW would use the FFT VI (it accepts complex numbers).  However, if you need to do this for a homework assignment and show the algorithm, LabVIEW has all the matrix and linear algebra functions you need to do this.  Consult the help for details.
(2,860 Views)
