6501DAQMX digital line count wrong
I'm trying to set up a simple DAQ application driving only 4 DAQ output lines (see attached screenshot). I identified FOUR data lines, Port 2, lines 0:3, which I expect to be P2.0,P2.1,P2.2,P2.3, and set up the FOUR boolean inputs for same. Error message tells me I have FIVE channels in my task, not FOUR. Can someone explain where the FIFTH channel is?
Message 1 of 16
(4,378 Views)
Hi hammer,
maybe "someone" could help if you would attach a screenshot or even better your VI?
Message 2 of 16
(4,374 Views)
I THOUGHT I DID ATTACH SCREENSHOT. HERE IT IS AGAIN.
Message 3 of 16
(4,369 Views)
Problem attaching. . again.
Message 4 of 16
(4,368 Views)
daqproblem.JPGI clicked BROWSE, selected the file DAQproblem.jpg, the path appears correctly in the Attachments window, and I click POST.
Message 5 of 16
(4,364 Views)
Hi hammer,
you can include pictures in the message text, there's this "tree"-like icon in the editor menu...
You can attach images as file - but BMP is prohibited for good reason. Use PNG instead...
EDIT:
You may even edit your older messages instead of creating new ones every minute...
Message 6 of 16
(4,362 Views)
Do you have "compatibility" mode turned on?  Also try with another browser.
Problem Uploading Attachments
Message 7 of 16
(4,360 Views)
I modified previous posting with screenshot successfully.
Message 8 of 16
(4,342 Views)
Is there a channel already defined in that task (likely from MAX)?  That would explain the 5th line in the task.  It would be better to leave the Task input unwired for the Create DAQmx Channel if you are only going to control those 4 lines.
Message 9 of 16
(4,339 Views)
I left Task input unwired and the problem went away, but I don't understand why the line count depends on the OC or Active function selection. If that is the case, then how do I set the OC or Active function w/o upsetting the  line count?
Previous to all this I did use the DAQ Assistant to set up multiple lines, many more than 5 with the same OC function, but I have since disconnected the DAQ, closed Labview 2011 and rebooted, hopefully clearing any previous setups, and the problem remains with the Task input wired. Besides, even if I did previously define tasks, shouldn't this vi overwrite and supercede previous setups?
Message 10 of 16
(4,324 Views)
