How to enable event for UDP reception in Labview
    i want to enable event for UPD recption. If any data comes to UDP port, then only this event has to execute.
Thanks & Regards,
Harish. G.
(3,319 Views)
I don't think this is available in labview, but maybe you can wire '-1' as timeout on UDP read (placed in while loop) and wire 'data out' to a Value (Signaling) property of a string control so it will fire the value change event once data is received.
(3,278 Views)
Right idea, but use a user event, don't use Value (Signaling). No need to trigger events on front panel items unnecessarily.
(3,263 Views)
