03-01-2022 02:01 AM
hai,
NI 6612 Pin out i have Some Query about this, How to Declarer the input and Output of the pin, (CTR 4 OUT/PFI 20/P0.20 and PFI 19/P0.19/CTR 5 SOURCE)
03-01-2022 06:50 AM
Some terminals are given multiple names b/c they can serve different kinds of purposes depending on your task config.
For the pin CTR 4 OUT/PFI 20/P0.20
Note: 2 different tasks could use the same terminal for different purposes at the same time, provided no more than 1 of them outputs to the terminal. One common technique I've used that for is to designate a PFI terminal as the trigger for a counter task and then define a DO task that will generate a brief pulse on Px.x to pulse it at a time of my choosing.
- Kevin P
