Step motor cannot move
Hi
I am a PhD student working on a project that need to control step motors. They are controlled by compactrio NI 9022 , module NI9512 and Labview. They are working fine previously on Real-time mode. However, as I tried to work on hybrid mode, motor cannot move and they still cannot work on Real-time mode after that. Now when I want to simply move the motor by straight-line move command, error -70233 occurs. When I want to move motor by interactive test panel, error -70299 happens. The screenshots of error are attached below.
What might be the possible solution?
(1,386 Views)
There are some special steps you need to take when using 951x with hybrid mode.  You can refer to here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Rj0SAE&l=en-US
https://forums.ni.com/t5/LabVIEW/RT-9512-modules-fault-when-using-hybrid-mode/td-p/1948655
Hope this helps.
(1,346 Views)
