Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
6i runtime engine
6i runtime engine
Charles Arnett
Member
05-03-2002
09:08 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
If I use Labview 6i to make some communication and file handler DLL's to use
with Delphi 6, will I havwe to use the large 6i runtime engine. The only
lthing I would use Labview 6i for is to make the DLL's
charles j arnett
0
Kudos
Message
1
of 2
(3,267 Views)
Reply
Re: 6i runtime engine
Lab Viewer
Active Participant
05-03-2002
11:05 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yes, you need the Run-Time Engine, even though your DLLs use just a part from its code.
Anyway, given today's computer resources, it's not that much.
Good Luck!
0
Kudos
Message
2
of 2
(3,267 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
